Harley Big Twin Replica Front Fender Raw with Trim Hole - Wyatt Gatling 74853
SKU 50-0137
$139.99
1399 ENTRIES 🎟️
$139.99 - $139.99
$139.99
1399 ENTRIES 🎟️
Raw fender trim rail, the decorative edge trim that dresses up the fender — a direct replacement for a dented, pitted, or missing stock trim rail. Fits 1949-1984 Harley Touring, Panhead, and Shovelhead models.
Wyatt Gatling #: 74853
Replica wide glide front fender has a raw finish with trim holes.
Fenders fit 41mm wide style glide forks with 16 inch wheel. Fender is equipped with trim holes in the front for fender tip. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Width: 7-1/4 inches
  • Suggested to use fender tip or side spears or fender kit.
1949-1984 FLH
