Harley Panhead Replica Front Fender Glide Raw - V-Twin 50-0742 - OEM 59000-48A
SKU 50-0742
$149.99
1499 ENTRIES 🎟️
$149.99 - $149.99
$149.99
1499 ENTRIES 🎟️
Raw replica-style front fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1949-1957 Harley Panhead models.
OEM #: 59000-48A
Replica glide front fender with a raw finish with correct early type bracket set riveted on.
Fender is without trim holes. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Width: 7-1/2 inches
1949-1957 FL
