Harley Big Twin Replica Front Axle Kit Parkerized - V-Twin 44-1983
SKU 44-1983
$129.99
1299 ENTRIES 🎟️
$129.99 - $129.99
$129.99
1299 ENTRIES 🎟️
Parkerized front axle, a direct OEM-spec replacement for a worn, bent, or rusted stock axle that keeps the wheel running true. Fits 1936-1948 Harley Flathead, Knucklehead, and Panhead models.
Replica parkerized replica spring fork front axle kit. Kit includes spacer nut kit axle sleeve and axle with a 9-1/2 inch bearing surface length for Big Twin with offset stock rockers.
*NOTE: For Spring Fork outside rockers with right side offset stock rockers without shock.
  • Bearing Surface: 9-1/2 inches
  • Surface w/o Thread: 8-3/4 inches
  • Overall Length:
  • Outer Diameter: 5/8 inches
  • Threads per Inch: 20
1936-1940 EL
1941-1948 FL
1937-1948 UL
