Replica Eaton Style Gas Set Cap Vented - Wyatt Gatling 72935P - OEM 61103-36
Wyatt Gatling #: 72935P · OEM #: 61103-36, 3507-36
Replica parkerized gas cap set is vented and for the right or left side. It has a taller profile for the authentic Eaton style look and measures 3/8 inch. For restoration purposes on 1942-1952 FL models.
This vented cap has a 5-16 inch knurled band on the top of the cap. Cap has a thickness of 1.76mm and a diameter of 2-1/2 inch. It is advisable to order caps in sets as they not match the existing cap brand or style. The cap shell is stamped steel assembled to cap seal and insides. These are the correct inchweight inch as they're not die cast.
- Height:.96 inches
- Cap height: 19 mm
- Knurl: 11mm
| 1936-1952 | EL |
| 1946-1964 | FL |
| 1936-1948 | U |
