Replica Eaton Style Gas Cap Vented - Wyatt Gatling 72935 - OEM 61103-36
SKU 38-7004
299 ENTRIES 🎟️
299 ENTRIES 🎟️
Wyatt Gatling #: 72935 · OEM #: 61103-36, 3507-36
Replica Eaton style chrome gas cap is vented and for the right or left side with a 7.75mm knurl.
This vented gas cap has a 5-16 inch knurled band on the top of the cap. Cap has a thickness of 1.76mm and a diameter of 2-1/2 inch. It is suggested to order caps in sets as they may not match the existing cap brand or style. The caps are the exact replica of the Original Eaton styles. The cap shell is stamped steel assembled to cap seal and insides. These are the correct inchweight inch as they're not die cast. The underside is marked with the Eaton logo. Exact replica of the Original Eaton style with a taller profile for the authentic look. Restoration Quality by V-Twin MFG!
  • Height:.96 inches
1936-1940 EL
1941-1964 FL
1938-1948 UL
