Replica Eaton Style Gas Cap Set Vented - Wyatt Gatling 72935SA - OEM 61103-36
SKU 38-7054
599 ENTRIES 🎟️
$59.99 - $59.99
599 ENTRIES 🎟️
Wyatt Gatling #: 72935SA · OEM #: 61103-36, 3507-36
Replica Eaton style brass gas cap set with zinc insert is vented for the right or left side with 7.75mm knurl.
This vented gas cap has a 5-16 inch knurled band on the top of the cap. Cap has a thickness of 1.76mm and a diameter of 2-1/2 inch. The cap shell is stamped steel assembled to cap seal and insides. These are the correct inchweight inch as they're not die cast. Exact replica of the Original Eaton style with a taller profile for the authentic look. Restoration Quality by V-Twin MFG! *NOTE: These are the 2 prong twist type.
  • Height:.96 inches
1936-1940 EL
1941-1964 FL
1938-1948 UL
