Replica Chrome Oil Tank - V-Twin 40-0432 - OEM 62504-38
OEM #: 62504-38, 3503-38
Replica chrome wrap-around oil tank includes seam-welded edges which show weld marks as on original tanks.
Tank is equipped with a screw in dipstick. Tank does not have battery rod tabs. Can be used in later applications with changing the battery rods to early style battery rods. *NOTE: The battery compartment dimensions are 5 inch wide x 4-1/2 inch long x 7 inch tall.
- Height Front: 7-1/8 inches
- Height Rear: 6-1/2 inches
- Depth: 8 inches
- Depth of Battery: 5 inches
- Width: 10 inches
- Battery Width: 5 inches
- Suggested to use #8115-1 #8114-1 or #9504-1 timing plugs.
- Suggested to use with #2071-10 Chrome Chain Guard and Oil Tank Mount Kit.
| 1936-1940 | EL |
| 1941-1957 | FL |
| 1938-1947 | UL |
