Replica Brass Linkert Carburetor Choke Shaft - V-Twin 35-0511 - OEM 27215-33
OEM #: 27215-33, 1231-33
Replica brass Linkert carburetor choke shaft has cam installed. Fits linkert carburetor M-18 M-41 M-42 M-51 M-52 M-54 and M-88.
Hole for choke lever screw may have to be enlarged for some applications. Choke shaft accept choke levers with build in detents Select types required and. NOTE: Accepts 6/32 x 1/4 fillister head slotted screw OEM #993 and 6 x 19/64 split lock washer OEM #7112.
| 1937-1952 | G |
| 1933-1948 | UL |
| 1941-1952 | W |
