Replica Black Oil Tank - V-Twin 40-0639
2020 New Production replica black painted wrap around oil tank features seam-welded edges which show weld marks as on original tanks.
Black tank has a zinc plated cap and is equipped with a screw in dipstick that includes a copper sealing washer. This tank does not have battery rod tabs. *NOTE: The battery compartment dimensions are 5 inch wide x 4-1/2 inch long x 7 inch tall.
- Height Front: 7 inches
- Height Rear: 6-1/2 inches
- Depth: 8-1/4 inches
- Depth of Battery: 5-1/4 inches
- Width: 10 inches
- Battery Width: 4-3/4 inches
- Suggested to use #8115-1 or #8114-1 Stock Type Timing Plug.
- Suggested to use with #9601-10 Inner Primary Cover and Chain Mount Kit.
- Suggested to use with #9504-1 Parkerized Timing and Oil Tank Plug.
| 1936-1940 | EL |
| 1941-1957 | FL |
| 1938-1947 | UL |
