Harley Big Twin Replica 80 Overhead Valve 3-1/2" Piston Set Standard Size - V-Twin 11-2778
Replica 3-1/2 inch bore piston set has a 8:1 compression ratio and is standard size. Piston set includes piston rings 2 wrist pins and 4 circlips. Pistons have a steel expansion control strut cast. **Note: Run engine at moderate speeds for at least 500 miles avoiding excessive running in lower gears in order to properly break-in new pistons and rings. Fits 1978-1984 Harley Big Twin, FX (Super Glide), FXR, Touring, and Shovelhead models.
| 1978-1984 | FL |
| 1979-1983 | FLT |
| 1978-1984 | FX |
| 1982-1983 | FXR |
