Harley Replica 74 Panhead Cylinder Piston Kit - V-Twin 11-0885
SKU 11-0885
Original price $589.99 - Original price $589.99
$589.99
5899 ENTRIES 🎟️
$589.99 - $589.99
$589.99
5899 ENTRIES 🎟️
This 74 inch Panhead cylinder and piston kit is bored and honed to 87.325mm with a stock compression of 8.5:1. Cylinders have original casting marks as on stock cylinders for this year group. Both cylinders are equipped with oil passages drilled through the wall to allow oil to return through the bore to the crank case. Pistons are pre-fit ready to run. Break in slowly first 500 miles. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003. Bore size is 3.4380 inch-3.4385 inch inner diameter. Installation instructions (PDF). Fits 1948-1952 Harley Panhead models.
  • Cylinders have M-1-0 date code.
1948-1952 FL
