Harley Big Twin Replica 74 Overhead Valve 3-7/16" Piston Set.060 Oversize - V-Twin 11-2762
SKU 11-2762
$139.99
1399 ENTRIES 🎟️
$139.99 - $139.99
$139.99
1399 ENTRIES 🎟️
Replica style 3-7/16 inch bore piston set has a 8.5:1 compression ratio and is.060 oversize. Piston set includes piston ring set 2 wrist pins and 4 circlips. Pistons have a steel expansion control strut cast. The skirt dimension across the widest part of the piston measures 3.485 inch. **Note: Run engine at moderate speeds for at least 500 miles avoiding excessive running in lower gears in order to properly break-in new pistons and rings. Fits 1941-1977 Harley Knucklehead, Panhead, and Shovelhead models.
1941-1977 FL
1971-1977 FX
