Replica 74 Knucklehead Long Block with Polished Rocker - V-Twin 10-1395
SKU 10-1395
Original price $10,419.99 - Original price $10,419.99
$10,419.99
104199 ENTRIES 🎟️
$10,419.99 - $10,419.99
$10,419.99
104199 ENTRIES 🎟️
Replica 74 inch long block Knucklehead with polished rocker boxes parkerized valve cover cups a Linkert inchBaby Butt inch manifold the motor sprocket and an 18mm spark plug set. Fully assembled and tested for oil pressure.
Unit features Replica crank cases overhead oiler provision from timing cover cast iron type flywheel assembled with stock rods and Torrington rollers with steel cages a valve train with tappet assembly featuring Sifton lightning cam pushrods chrome pushrod covers smooth cam cover and a Replica M51 Linkert carburetor. Replica cast iron cylinders are fitted with 8.5:1 pistons and Hastings rings replica cast iron oil pump with easrly style iron cover and a distributor mechanical advance with corresponding relay mount with distributor post guide slot. The inchBaby Butt inch style manifold accepts Linkert 3-bolt type carburetors. Manufacturer's Bill of Sale supplied. **NOTE: Must order generator separately not included.
1941-1947 FL
