Harley Panhead Rear Hydraulic Brake Shoe Springs - V-Twin 13-9233 - OEM 41836-58
SKU 13-9233
299 ENTRIES 🎟️
299 ENTRIES 🎟️
Drum brake shoe spring, a clean swap for a weak, rusted, or broken stock spring that's keeping the shoes from seating or releasing properly. Fits 1958-1962 Harley Panhead models.
OEM #: 41836-58, 41837-58
Rear brake shoe spring set for hydraulic brake.
Set of two. Upper brake shoe spring installation requires brake shoe cams to be turned inward. The short hook end of the spring must be placed into the slotted hole of the front shoe from underneath the long end is placed into the outer round hole of the rear shoe from above.
  • Length: 4-1/4 inches
1958-1962 FL
