Harley Panhead Rear Hydraulic Brake Backing Plate Kit Chrome - V-Twin 23-9240
Chrome rear hydraulic brake backing plate kit, pre-assembled with the shoes, springs, and cam or wheel cylinder already installed — a direct, bolt-in replacement for a worn-out stock plate assembly. Fits 1958-1962 Harley Panhead models.
Kit includes chrome backing plate with wheel cylinder shoe set and springs installed.
Hose fitting and banjo bolt is supplied. Order proper cast drum and axle kit separately.
- Suggested to use with hydraulic cast brake drum Suggested to use with rear axle kit
- Suggested to use axle kit.
| 1958-1962 | FL |
