Harley Panhead Rear Hydraulic Brake Backing Plate Kit Black - V-Twin 23-9241
SKU 23-9241
Sold out
$229.99
2299 ENTRIES 🎟️
$229.99 - $229.99
$229.99
2299 ENTRIES 🎟️
Black rear hydraulic brake backing plate kit, pre-assembled with the shoes, springs, and cam or wheel cylinder already installed — a direct, bolt-in replacement for a worn-out stock plate assembly. Fits 1958-1962 Harley Panhead models.
Kit includes black backing plate with wheel cylinder shoe set and springs installed.
Hose fitting and 3/8 inch banjo bolt is supplied. Order proper cast drum and axle kit separately.
  • Suggested to use with hydraulic cast brake drum Suggested to use with rear axle kit
  • Suggested to use axle kit.
1958-1962 FL
