Harley Big Twin Rear Hydraulic Brake Backing Plate Kit Black - Edart 19140
by Edart
SKU 23-9242
$249.99
2499 ENTRIES 🎟️
$249.99 - $249.99
$249.99
2499 ENTRIES 🎟️
Black rear hydraulic brake backing plate kit, pre-assembled with the shoes, springs, and cam or wheel cylinder already installed — a direct, bolt-in replacement for a worn-out stock plate assembly. Fits 1963-1972 Harley Panhead and Shovelhead models.
Edart #: 19140
Kit includes black backing plate with wheel cylinder shoe set and springs installed.
Hose fitting and banjo bolt is supplied. Order proper cast drum and axle kit separately.
  • Suggested to use hydraulic cast brake drum Suggested to use rear axle kit
  • Suggested to use axle kit.
1963-1972 FL
1971-1972 FX
