Harley Big Twin Rear Fender U Strap Raw - V-Twin 50-0528 - OEM 59737-34
Raw fender brace/bracket hardware that supports the fender against vibration, a direct replacement for a cracked, bent, or missing stock part. Fits 1934-1957 Harley Flathead, Knucklehead, and Panhead models.
OEM #: 59737-34
2023 New Production rear fender u strap features a raw finish. Horseshoe shape for attaching stay bars on rear hinged portion of fender. Brackets are raw steel construction.
Features one rivet hole on one end and two rivet holes on the other end. *NOTE: This brace is one type only for 5/8 inch or 7/8 inch fender brace widths. *NOTE: Must order mount bolt kit separately. Connects slotted rear straps with carriage bolts use rear fender strap set with rear straps.
- Suggested to use with Rigid Rear Fender Strap Set
| 1936-1952 | EL |
| 1941-1957 | FL |
| 1934-1936 | VL |
