Harley Rear Fender Kit Bobbed with Cateye Tail Lamp - V-Twin 50-0755
Fender-mounted lamp/light part, a direct replacement for a cracked, burned-out, or missing stock part. Universal fit for most Harley fender applications.
Bobbed rear fender kit includes steel fender chrome struts chrome tail lamp bracket and cateye tail lamp.
We suggest pre fitting the fender prior to painting. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Outside Width: 7-3/8 inches
- Inside Width: 7-1/8 inches
- Fender Length: 31 inches
