Rear Fender Edge Lamp Kit - Wyatt Gatling 77072 - OEM 73420-11 - Sportster 2004-2013
Wyatt Gatling #: 77072 · OEM #: 73420-11
Add style to your chopped rear fender with this low-profile fender edge lamp kit with red LEDs and a red lens.
This fender lamp glows red when the ignition is on. When the brake is applied the red glow intensifies. For use with models which are equipped with a chopper rear fender and a side mount license plate. WARNING: Disconnecting your D.O.T required brake lamp could reduce your visibility to others and result in serious injury.
| 2004-2013 | XL |
