Harley Softail Rear Dunlop D401 200/55R X 17 Blackwall - Dunlop 0302-0407 - OEM 43970-08
by Dunlop
SKU 46-0236
Sold out
$369.99
3699 ENTRIES 🎟️
$369.99 - $369.99
$369.99
3699 ENTRIES 🎟️
This rear blackwall tire features an advanced tread pattern. With the advanced tread pattern and compound it improves the grip on wet or dry roads. Tire has an offset center groove for improved stability in the rain 3 ply Nylon and 2 fiber glass belts and a H-speed rating. **WARNING: Newly fitted tires should not be subjected to sudden acceleration hard cornering or maximum power or braking for at least 100 miles. Loss of control and serious injury or death may be a result in doing so. By waiting till the 100 mile break in the driver will become accustomed to the feel of the new tires or tire combination. You should check and adjust inflation pressure to recommended levels after tires cool for at least 3 hours following run in. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. Fits 2008-2011 Harley Softail models.
Dunlop #: 0302-0407 · OEM #: 43970-08
2008-2011 FLSTSB
0 Rear
