Rear Drum Brake Master Cylinder - V-Twin 23-0096 - OEM 41761-58
OEM #: 41761-58
Chrome non polished Wagner style rear drum master cylinder is assembled with internals and includes cap and boot. Has rough surface with chrome plated finish.
Master cylinder is 3/4 inch bore. Master cylinder is cast iron difference internal. *NOTE: Needs inverted flair brake fitting and steel brake line.
- Suggested to use DOT 5 fluid.
| 1958-1972 | FL |
| 1971-1972 | FX |
