Rear Chain Oil Kit Zinc Plated - V-Twin 12-1280
SKU 12-1280
Zinc plated rear chain oiler kit. The fitting is installed between the oil pressure switch and oil pump body.
The fitting has adjustment screw and lock nut to allow oil flow rate to be adjusted. Once fitting is installed route oiler tube over transmission to rear chain drive. *NOTE: Must order sealing washer separately.
  • Suggested to use with Oil Fitting Washer.
1936-1940 EL
1941-1969 FL
1937-1948 U
