Harley Knucklehead Rear Brake Backing Plate - V-Twin 49-0357 - OEM 41650-36
SKU 49-0357
Original price $499.99 - Original price $499.99
$499.99
4999 ENTRIES 🎟️
$499.99 - $499.99
$499.99
4999 ENTRIES 🎟️
Rear mechanical brake backing plate, the plate the shoes, cam, and pivot stud mount to — a direct replacement for a cracked, bent, or worn stock plate. Fits 1936 Harley Knucklehead models.
OEM #: 41650-36
Rear brake backing plate features a gloss black finish.
The 1936 only rear brake on 61 EL models utilizes front shoes springs cam and pivot studs from the same year! Note: Grease fitting for brake cam may need to removed and relocated for better access. Moisture drain tube is located at the 6:00 position that is behind the left axle plate. *NOTE: Order related parts separately.
1936 EL
