Harley Rear Axle Spacer 3/4 Inner Diameter - Paughco 33D2
Axle spacer kit for the rear wheel, setting correct hub spacing and including the washers and nut needed for a clean install. Universal fit for most Harley axle applications.
Paughco #: 33D2
Chrome rear axle spacer have milled flat section on one end to fit rigid frame slots. The collar has an overall length of 1-13/16 inch x 3/4 inch inner diameter.
- Overall Length: 1-13/16 inches
- Inner Diameter: 3/4 inches
- Suggested to use with collar
- Suggested to use with rear axle nut & washer kit
- Suggested to use with #7704-2 rear chain adjuster set
