Harley Big Twin Raw Rigid Rear Fender Assembly - V-Twin 50-0363
SKU 50-0363
$409.99
4099 ENTRIES 🎟️
$409.99 - $409.99
$409.99
4099 ENTRIES 🎟️
Raw rigid-style rear fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1939-1947 Harley Flathead and Knucklehead models.
2022 New Production rigid rear fender with 5/8 inch wide braces includes tail section. The fender may require metal work for alignment and fit before primer and paint. Includes tube for wire tail lamp loom.
Features a two piece spot welded skirt. Fender is fully assembled and riveted together with hinge. Before finishing with primer or paint installer must prepare fender by checking alignment of fender tail and bracket. All hinge fenders must be hand fitted at hinge and pin area. Alignment will have to be adjusted and tweaked to fit your components. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Includes replica rigid rear fender hinge V-Twin. Patience is required for proper installation! We suggest pre-fitting fender prior to painting. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Large Loop Width: 1/2 inches
  • Narrow Loop Width: 3/8 inches
  • Pin: 5.4mm
  • Fender Width: 7-1/4 inches
  • Suggested to use with Rear Fender Trim Set.
  • Fender hinge construction updated 2021.
1939-1947 EL
1939-1947 FL
1939-1947 UL
