Harley Raw Rear Axle - V-Twin 44-0638 - Big Twin 0+
SKU 44-0638
499 ENTRIES 🎟️
499 ENTRIES 🎟️
Raw, unfinished rear axle ready for your choice of finish — a direct OEM-spec replacement for a worn, bent, or rusted stock axle. Universal fit, replaces the stock axle on most Harley applications.
Raw axle with 3/4 inch threaded ends has a 11-3/8 inch bearing surface length and can be used to replace a worn out or damaged axle.
These axles features 1 inch of 3/4 inch x 16 threads at each end. An acorn pike or nyloc nut can be used. Locators are set to fit axles in order to stock rigid frame axle plates.
  • Bearing Surface: 11-3/8 inches
  • Surface w/o Thread:
  • Overall Length: 13-1/2 inches
  • Outer Diameter: 3/4 inches
  • Threads per Inch: 16
  • Suggested to use nut kit.
