Primo Pro Clutch Kit - Rivera-Primo Products 1056-0003 - Evolution 1985-1990
Rivera-Primo Products #: 1056-0003
Pro-clutch kit converts old style clutch packs to smooth modern diaphragm spring function.
Pro-Clutch by Rivera Engineering is available for early chain or belt drive with wet or dry clutch. Kit includes clutch hub with bearing clutch discs (friction and steel) diaphragm spring spring retainer pressure plate and 4 shoulder bolts. 1984-up kits ultilize existing clutch basket supplies clutch hub to allow use of clutch plates that increase surface area by 100% to reduce slipping. Use with existing clutch hub.
| 1986-1990 | FLST |
| 1985-1990 | FLT |
| 1985-1990 | FXR |
| 1985-1990 | FXST |
