Polished Oil Pump Assembly - Sifton 20276
by Sifton
SKU 12-9969
$349.99
$349.99 - $349.99
$349.99
Sifton #: 20276
Sifton oil pump assembly includes all necessary fittings snap rings keys gaskets and mounting bolts for a complete installation. Oil pump has a polished finish.
Oil line available separately. *NOTE: Has the adjuster for the chain oiler. *NOTE: The bolts included are both 1/4 inch- 20 the longer one is 2-3/4 inch end to end with 1 inch threads and the short one is 1-1/2 inch end to end with 1-1/4 inch threads.
  • Features improved oil pump pressure regulation that will ensure correct oiling to all areas of Big Twin engines.
  • 1970-80 requires drilling operation use oil pump drill fixture
  • Suggested to use with Rigid Oil Line Set for Billet Pump
  • Suggested to use with Rigid Oil Line Set for Billet Pump Zicad Plated
1936-1940 EL
1941-1972 FL
1971-1972 FX
