Harley Big Twin Pinion Shaft and Gear 3 Piece Set - V-Twin 10-1497
SKU 10-1497
$119.99
1199 ENTRIES 🎟️
$119.99 - $119.99
$119.99
1199 ENTRIES 🎟️
Pinion shaft and gear set includes a machined and ground to factory specifications engine shaft a 21 tooth standard tapered pinion shaft gear with a 1.43 inch outer diameter and a pinion shaft gear end nut *NOTE: Check spline timing in relation to key way 12 o'clock on top and oil hole large spline at 3 o'clock before installing in flywheel for final assembly and truing of flywheels. Fits 1939-1953 Harley Knucklehead and Panhead models.
1939-1952 EL
1941-1953 FL
