Pinion Gear Puller Tool Kit - V-Twin 16-0129 - OEM 96830-51
SKU 16-0129
$129.99
1299 ENTRIES 🎟️
$129.99 - $129.99
$129.99
1299 ENTRIES 🎟️
OEM #: 96830-51
Puller tool kit is used to remove and install the pinion gear.
Can be used to install gear on 1951-1953 Big Twin 61 inch and 74 inch overhead valve. This is a 4 piece set.
  • Order nut wrench separately.
  • Used to install pressed on splined pinion gears on 1939-1953 Big Twin.
  • Used to remove pinion gear on 1939-1989 Big Twin and 1957- 1976 XL.
1939-1940 EL
1941-1984 FL
1986-1998 FLST
1979-1998 FLT
1971-1984 FX
1991-1998 FXD
1982-1994 FXR
1984-1998 FXST
1967-1976 XL
