Pingel Metric Smooth Petcock Left Spigot with Nut Chrome - Pingel 1311-CR
Pingel #: 1311-CR
Pingel chrome metric smooth petcock features 22mm inlet with left spigot and adapter nut.
Petcock is a single outlet reserve with a round design and a 5/16 inch hose barb. Unit features a 22mm inlet and a metric adapter nut includes right and left hand thread so once installed adapter nut can be loosened valve put in the desired position and nut retightened. No need to use telfon tapes meaning less chance of leakage. Designs are made for a seated position on the motorcycle with the hose outlet facing a direction to ease fuel line hookup.
- If the valve is mounted on the left side the hose outlet faces forward. If the valve is mounted on the right side the hose outlet faces the rear.
| 1975-1984 | FL |
| 1986-1994 | FLST |
| 1975-1984 | FX |
| 1991-1994 | FXD |
| 1982-1994 | FXR |
| 1984-1994 | FXST |
| 1975-1995 | XL |
