Partial 4-Speed Kick Starter Kit - V-Twin 22-0310
SKU 22-0310
$209.99
$209.99 - $209.99
$209.99
Partial 4-speed kick starter kit includes all components except the arm cover and pedal.
Includes the clutch lever finger shaft assembly. Order clutch lever shaft and finger kit to complete assembly available separately. *NOTE: When installing any type of our 1974-1980 kick starter kits on 1980-1985 4-speeds a late bearing retiainer which incorporates a kick starter stop built in is required. *NOTE: The clutch release shaft is not included. *NOTE: Thrust washer with counter sink for kick shaft faces kicker spring for installation.
  • Suggested to use with Clutch Release Shaft Kit
1936-1940 EL
1941-1984 FL
1971-1984 FX
1937-1948 UL
