Harley Big Twin Panhead/Shovelhead Motor Case Set - V-Twin 10-1875
Panhead/Shovelhead motor case set for flat side models with cast aluminum inner primary cover. Set includes tapered bearing assembly for left side and case race on right side. For standard bore cylinders 74 inch or 80 inch. Accepts Shovelhead OHO line to the heads. Set accept cast inner cover as original 1965-1969 FLH models. Standard bore cases accept 74 inch or 80 inch cylinders and 3.680 inch for cylinder spigot. May be fitted with a tin inner primary cover. Bore to fit Y oil line. Fits 1965-1969 Harley Panhead and Shovelhead models.
| 1965-1969 | FL |
