Panhead Engine Assembly 80", " - V-Twin 10-1965 - Big Twin 1965-1969
SKU 10-1965
Original price $6,909.99 - Original price $6,909.99
$6,909.99
69099 ENTRIES 🎟️
$6,909.99 - $6,909.99
$6,909.99
69099 ENTRIES 🎟️
80 inch Panhead engine assembly is completely assembled and tested for oil pressure.
1965 style Panhead 80 inch long block features V-Twin crankcase Sifton oil pump and breather assembly stock stroke flywheel Timken bearings and a stock lift cam installed with a matched pinion gear. Cylinders are stock with 8.5:1 compression cast pistons. Top end includes single plug Panhead heads fitted with rocker arm assemblies chrome pan covers with thick D rings chrome steel pushrod covers and an OKO shorty carburetor. Order 2 brush generator separately. Entire unit is pre run and factory tested for oil pump pressure. **NOTE: Charging system is not included.
1965-1969 FL
