Harley Big Twin Overhead Valve Linkert Carburetor Float Bowl Brass - V-Twin 35-1015
Brass carburetor float part that sets fuel level in the float bowl, a direct replacement for a worn, sticking, or waterlogged stock float component. Fits 1936-1965 Harley Knucklehead and Panhead models.
Overhead valve linkert carburetor float bowl features a brass construction with a flat top and provision for drain screw hole.
Includes linkert carburetor float pivot pin with caps for float pivot arm. Order pivot arm separately. Needle valve seat opening is milled flat and sealed by carburetor body after assembly. Exact fit and function!
| 1936-1952 | EL |
| 1941-1965 | FL |
