Harley Big Twin & Sportster OKO 47mm Shorty Carburetor Kit Alloy - V-Twin 35-0292 - Ironhead 1977-1984
Alloy carburetor that drops in as a complete, ready-to-tune unit instead of piecing one together from individual parts. Fits 1977-1984 Harley Big Twin, FX (Super Glide), Sportster, and Shovelhead models.
Performance 47mm shorty caburetor with an alloy finish. Kit will accept S&S bolt pattern air filter assemblies. It has a relocated accelerator pump nozzle for increased throttle response. Uses flat sealing ring for manifold.
Includes chrome round mesh air cleaner with S&S bolt pattern. This is the R-2 version of the OKO type replacement carburetor. OKO shorty carburetor accepts S&S air cleaners Shorty E carburetor components and rebuild parts. All pieces interchangeable. Air cleaner mount bolt configuration is S&S inchE inch type. *NOTE: Requires carburetor support bracket to mount to the air cleaner and stud between the cylinders. Additonal holes in the air cleaner backing plate may be required for mounting. Use with dual cable throttle/assembly cable. *NOTE: The main jet installed is #190. *NOTE: 1-7/8 inch = 47mm. *NOTE: We suggest using Loctite for proper installation.
- Required to use with OKO Shorty Carburetor Enrichment Assembly if used with custom air cleaners because the enricher will have to be changed.
| 1977-1984 | FL |
| 1977-1984 | FX |
| 1977-1984 | XL |
