Harley Big Twin & Sportster OKO 42mm Flatside Carburetor Kit - V-Twin 35-1880 - Ironhead 1966-1984
SKU 35-1880
$309.99
3099 ENTRIES 🎟️
$309.99 - $309.99
$309.99
3099 ENTRIES 🎟️
Carburetor that drops in as a complete, ready-to-tune unit instead of piecing one together from individual parts. Fits 1966-1984 Harley Big Twin, FX (Super Glide), Sportster, and Shovelhead models.
OKO 42mm flatside carburetor kit includes vertical flange adapter rubber sleeve air cleaner adapter lower carburetor stud and strap bracket. *Shown installed on a 1966 flatside Shovelhead.
42mm band type manifold included with adapter rings to fit o-ring style manifold heads. Includes 4 main jets and 2 pilot jets. The carburetoer outer flange adapter is a molded rubber sleeve with a CV pattern alloy flange. Requires dual cable push-pull operation. Twist grip and cables available separately.
  • Suggested to use with stock cables: 34inch Stainless Steel Throttle and Idle Cable set or 34.92inch Black Throttle and Idle Cable Set.
  • Suggested to use with 8+ cables: 41-1/2inch Stainless Steel Throttle and Idle Cable Set or 41-1/2inch Black Throtle and Idle Cable Set.
  • Suggested to use with Dual Handlebar Throttle Hanlde and Grips.
1966-1984 FL
1971-1984 FX
1966-1984 XL
