Oil Pump Hardware Kit - V-Twin 12-0177 - Ironhead 1957-1976
SKU 12-0177
$69.99
$69.99
$69.99
$69.99
$69.99
$69.99
Kit includes oil pressure switch fitting pressure switch straight male gas/oil fitting oil pump check valve spring 3/8 inch clutch ball bearing drain plug oil pump dowel feed pin retainer half key gaskets and snap rings.
Order gears and oil pump body separately.
| 1957-1976 | XL |
