Oil Line Fitting Kit - V-Twin 40-0505
SKU 40-0505
399 ENTRIES 🎟️
399 ENTRIES 🎟️
Our oil line fitting kit includes four cadmium plated fittings for use with stock lines when an external oil filter is used.
NOTE: These fittings will work with a oil filter canister line set only. Includes one oil filter line for your oil tank OEM# 63524-50 two oil filter line for your filter housing body OEM# 63525-50 and oil cover fitting for your oil pump OEM# 26424-50. All available separately. *NOTE: Zicad is a dull shade of zinc similar to cadmium.
  • Suggested to use with Chrome Oil Filter Line Set.
  • Suggested to use with Cadmium Oil Filter Line Set.
1940-1957 FL
