MotoBatt Mini 12 Volt Battery - Motobatt MB5.5U
SKU 53-0543
$74.99
749 ENTRIES 🎟️
$74.99 - $74.99
$74.99
749 ENTRIES 🎟️
Motobatt #: MB5.5U
Mini 12 volt battery (MB5.5U) is a dry charged battery. Battery is for 5.5 amps for Panhead custom applications.
Features: 20% more amp hour capacity 20% more cold cranking amps heavy duty pure lead calcium cast grids for high strength more surface area per plate for superior perforamnce and longevity military grade absorbed glass matt separators vibration resistant multi-terminal design easy to add accessories extremely low self discharge rate factory activated and no acid to fill. Simply charge and go!
  • Length: 5-5/16 inches
  • Width: 2-5/16 inches
  • Height: 5-1/8 inches
  • Cold Cranking Amps: 90
  • Charging Information: Prior to filling with electrolyte acid remove vent hole plug and fill battery. Charge battery with a 4 amp charger with fill caps removed for 24 hours.
