Harley Momentary to Latching Switch Module Converter - Namz NSC-01
Intended for custom applications where momentary switches are used for a hi-low headlamp switch and run/kill switch. Includes heat shrink. Module converts the momentary switch into a hi/low latching for the headlamp and on/off latching for the kill switch. Simply add fused power a ground wire and connect your momentary switches through for the latching functions you need. Universal fit for most Harley applications.
Namz #: NSC-01
