Harley Mini Chrome Push Button Two-Wire Switch - Volt Tech H21-0211
SKU 32-0867
249 ENTRIES 🎟️
249 ENTRIES 🎟️
Mini Push Button Switch is a 12mm round chrome push button s tyle which is great for use in custom wiring applications. T wo wire type requires a starter relay. The switch can be used in a variety of applications such as turn signal starter or horn switch. Switch is 2 wire type and requires the use of a relay to use as a inchhigh-low inch beam. Switch has two 20 inch wires with 8mm x 1 inch thread. Universal fit for most Harley applications.
Volt Tech #: H21-0211
  • Wire Length: 20 inches
