Mini 12 Volt Battery - V-Twin 53-0527
Mini 12 volt battery (12N5.5A-3B) is a dry charged battery.
For custom application on 1948-1964 FL Panheads. Battery has a right side vent position and and has a maximum charge rate of 0.6. Do not overfill battery fill to the line level as noted. When refilling use distilled water only. **NOTE: Requires filling with electrolyte acid available from your local auto parts store.
- Length: 4-1/19 inches
- Width: 3-19/32 inches
- Height: 4-1/2 inches
- Charging Information: Prior to filling with electrolyte acid remove vent hole plug and fill battery. Charge battery with a 4 amp charger with fill caps removed for 24 hours.
