Harley Michelin Commander II Tire 100/90 B19 Front - Michelin 0305-0281
SKU 46-0902
$289.99
2899 ENTRIES 🎟️
$289.99 - $289.99
$289.99
2899 ENTRIES 🎟️
Michelin commander II tire is designed for extended mileage and features aramid tread plies to resist centrifugal growth and provides excellent stability. Also features a square bead wire that improves casing and ease of installation. **WARNING: Newly fitted tires should not be subjected to sudden acceleration hard cornering or maximum power or braking for at least 100 dry miles. Loss of control and serious injury or death may be a result in doing so. By waiting till the 100 mile break in the driver will become accustomed to the feel of the new tires or tire combination. You should check and adjust inflation pressure to recommended levels after tires cool for at least 3 hours following run in. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. Universal fit for most Harley applications.
Michelin #: 0305-0281
0 Front
