Harley Big Twin Mechanical Brake Rod Clevis Long - Edart 19002Z - OEM 42273-30
by Edart
SKU 23-0444
299 ENTRIES 🎟️
299 ENTRIES 🎟️
Mechanical brake rod clevis, the forked end that pins the rod to the pedal or brake arm — a direct replacement for a worn, stripped, or bent stock clevis. Fits 1936-1957 Harley Flathead, Knucklehead, and Panhead models.
Edart #: 19002Z · OEM #: 42273-30, 4067-30
Parkerized brake rod long clevis.
*NOTE: Must order hardware separately.
  • Required to use with Mechanical Brake Rod Clevis Pin.
1936-1940 EL
1941-1957 FL
1937-1948 UL
