Harley Big Twin & Sportster Magneto Drive and Base Kit - V-Twin 32-1293 - Sportster 1936-1973
SKU 32-1293
$299.99
2999 ENTRIES 🎟️
$299.99 - $299.99
$299.99
2999 ENTRIES 🎟️
Kit will accept hex drive Magneto. Includes cast base gear pin shaft mount plate tachometer drive plug shouldered mount bolts seal and gasket. NOTE: This is the real deal Sportster advance mechanism as the factory supplied from 1965-1970 on the XLCH models Get Real! All components as original. Must have the cast base installed as original on XLCH models. Base will accept tachometer drive gear and cable. Fits 1936-1973 Harley K Model, Sportster, and Flathead models.
  • Suggested to use with Magneto Base Adapter Plate.
1936-1973 G
1952-1956 K
1936-1952 U
1957-1970 XL
