Harley M8FI Gen 9 EFI Controller - Daytona Twin Tech 17818 - Milwaukee-Eight Touring 2021-2024
Daytona Twin Tec M8FI Gen 9 Auto Tune fuel injection controller is fully programmable plug in replacement featuring a billet aluminum housing with a black anodized finish. Quickly auto-tune fuel curves for front and rear cylinders on a Dyno or on-road. The robust alpha-N fuel control eliminates problems with long duration/high overlap camshafts. Windows software provides custom programming and data analysis. Features extended data logging and diagnostics. Data flash memory stores full 60 minutes of operating data at 10 samples/second. User input functions are: two-stage rpm limiter nitrous retard and shift kill. User output functions are: shift light nitrous activation and electric shifter. *NOTE: Does not work on models with VVT (variable valve timing). **NOTE: Some aftermarket exhaust systems may require modifications or relocation of their O2 sensor port bungs to avoid clearance issues. Fits 2021-2024 Harley Touring models.
Daytona Twin Tech #: 17818
| 2021-2024 | FLHR |
| 2021-2024 | FLHT |
| 2021-2024 | FLHX |
| 2021-2024 | FLTR |
