Harley Big Twin M8 EFI Body Support Bracket Stainless Steel - V-Twin 34-0176 - Twin Cam 2017+
Stainless steel air cleaner support bracket that holds the air cleaner assembly steady against engine vibration, a direct replacement for a cracked or missing stock bracket. Fits 2017+ Harley Softail and Touring models.
EFI air cleaner body support bracket features a stamped stainless steel finish. For M8 50mm applications.
Use with alloy adapter plate for mounting EFI air cleaner backing plate. *NOTE: Requires spacer between bracket and carburetor. Order breather bolt kit separately.
| 2018-UP | FLST |
| 2017-UP | FLT |
| 2018-UP | FXST |
