Harley Big Twin M8 EFI Body Support Bracket Black - V-Twin 34-1643 - Twin Cam 2017+
SKU 34-1643
449 ENTRIES 🎟️
449 ENTRIES 🎟️
Black air cleaner support bracket that holds the air cleaner assembly steady against engine vibration, a direct replacement for a cracked or missing stock bracket. Fits 2017+ Harley Softail and Touring models.
EFI air cleaner body support bracket features a stamped black finish. For M8 50mm applications.
Use with alloy adapter plate for mounting EFI air cleaner backing plate. *NOTE: Requires spacer between bracket and carburetor. Order breather bolt kit separately.
  • Suggested to use with EFI Air Cleaner Adapter Spacer Alloy
2018-UP FLST
2017-UP FLT
2018-UP FXST
